DeleteRecord Method for a Business Component
The DeleteRecord method removes the current record from a business component. This method does not return any information.
Format
BusComp.DeleteRecord
No arguments are available.
Used With
COM Data Control, COM Data Server, Siebel Java Data Bean, Mobile Web Client Automation Server, Server Script
Examples
This Siebel VB example deletes accounts with a status of Inactive:
Sub DeleteInactiveAccounts()
Dim objBO as BusObject
Dim objBC as BusComp
Set objBO = TheApplication.GetBusObject("Account")
Set objBC = objBO.GetBusComp("Account")
With objBC
.ClearToQuery
.SetSearchSpec "Status", "Inactive"
.ExecuteQuery ForwardBackward
Do While .FirstRecord
.DeleteRecord
Loop
End With
Set objBC = Nothing
Set objBO = Nothing
End Sub
Siebel CRM moves the cursor to the next record after it runs the DeleteRecord method. Do not use the NextRecord method after you use the DeleteRecord method in a loop because this configuration causes Siebel CRM to skip deleting the last record in the loop. If you use the DeleteRecord method on the last record, then the cursor points to nothing.
