Example of Calling More Than One Object Interface Method in Siebel VB
The following example uses the Select statement in Siebel VB:
Dim iReturn As Integer
iReturn = ContinueOperation
Select Case methodName
Case "PushOpportunity"
your custom code
iReturn = CancelOperation
Case "Stage3"
your custom code
End Select
object_PreInvokeMethod = iReturn
