Methods That Control Navigation Flow of Siebel Applications
The following object interface methods allow your configuration to control the navigation flow of a Siebel application:
These object interface methods explicitly specify the view, applet, or control that Siebel CRM displays or makes active. The following items apply for these methods:
Sets the active view to the view that you specify.
Your configuration cannot call these methods from Browser Script.
They are useful only if you access a Siebel object interface in one of the following ways:
From Siebel VB
From the Mobile Web Client Automation Server
If you access a Siebel object interface through COM Data Control, COM Data Server, or Siebel Java Data Bean, then no Siebel user interface is present.
Siebel CRM stores the properties of a Siebel object in the Siebel runtime repository. You cannot use an object interface method in Siebel VB to modify these properties at run time. A business component is an example of a Siebel object.
