RefineQuery Method for a Business Component
The RefineQuery method refines a query. This method does not return any information.
Format
BusComp.RefineQuery
No arguments are available.
Usage
Unlike the ClearToQuery method, the RefineQuery method retains the existing query specification and allows you to add search conditions that include those fields that Siebel CRM has not set through a previous search expression. The RefineQuery method is most useful if you use it with the GetNamedSearch method. For more information, see ClearToQuery Method for a Business Component and GetNamedSearch Method for a Business Component.
Used With
COM Data Control, COM Data Server, Siebel Java Data Bean, Mobile Web Client Automation Server, Server Script
Examples
The following Siebel VB code uses RefineQuery:
me.SetSearchSpec "Status", "Open"
me.ClearToQuery
me.ExecuteQuery
me.RefineQuery
me.SetSearchSpec "Substatus", "Assigned"
me.ExecuteQuery
