TraceOn Method for an Application
The TraceOn method turns on tracing for allocations and deallocations of Siebel objects and SQL statements that Siebel CRM creates. This method does not return any information.
Format
Application.TraceOn(filename, type, selection)
The following table describes the arguments for the TraceOn method.
Argument | Description |
filename |
Output filename for trace messages. If you do not use this argument, then Siebel CRM logs tracing information to the Object Manager log file. More information about the filename argument is provided later in this topic. |
type |
The type of tracing to start. You can use the following values:
selection |
Identifies the Siebel objects that Siebel CRM must trace for the Allocation trace type. This argument is "" if the trace type is SQL:
Filename Argument of the TraceOn Method
You can use the following values for the filename argument:
$p. Substitutes the process Id for the filename.
$t. Substitutes the thread Id for the file name.
For example:
TheApplication().TraceOn("C:\\temp\\trace_$p_$t.txt", "Allocation", "All");
This code causes Siebel CRM to
log trace files to the trace_1496_1412.txt file in the C:\temp\trace
folder.
To make sure the filename argument is unique, you must place a separator between the $p and $t values. For example, assume you do not use a separator and the following items are true:
The process id for user A is 1 and the thread id is 12.
The process id for user B is 11 and the thread id is 2.
In this situation, the file name is trace_112.txt for user A and for user B, so Siebel CRM logs trace information for each user to the same file.
If you add a separator between the process id and the thread id, then the file names are unique and Siebel CRM logs trace information to a separate file for each user. For example:
trace_1_12.txt
trace_11_2.txt
Usage
To turn off tracing, you must call the TraceOff method. If you attempt to call the TraceOn method with a different filename without first calling TraceOff, then Siebel CRM writes trace information to the new trace file name. The old file remains open and is locked. You can issue multiple TraceOn statements to the same trace file.
It is recommended that you do not use the Trace method or the TraceOn method in a production environment. For more information, see Trace Method for an Application.
Used With
COM Data Control, COM Data Server, Siebel Java Data Bean, Mobile Web Client Automation Server, Server Script
Examples
The following example is for COM Data Server:
Private Sub TraceOn_Click()
Dim ErrCode As Integer
SiebelApplication.TraceOn "c:\temp\trace.txt", "allocation",
"all", ErrCode
If (ErrCode = 0) Then SiebelApplication.TraceOn
"c:\temp\trace.txt", "SQL", "",ErrCode
"Start of Tracing!",
ErrCode
End Sub
The following example is in Siebel eScript:
function BusComp_PreSetFieldValue (FieldName, FieldValue)
TheApplication().TraceOn("C:\\temp\\trace.txt", "Allocation", "All");
TheApplication().TraceOn("C:\\temp\\trace.txt", "SQL", "");
TheApplication().Trace("start tracing!");
return (ContinueOperation);
The following example is in Siebel VB:
Sub Button2_Click
TheApplication.TraceOn "C:\temp\trace.txt", "allocation",
"all"
TheApplication.TraceOn "C:\temp\trace.txt", "sql", ""
TheApplication.Trace "start of tracing!"
End Sub
For example trace output, see Trace Method for an Application.
The following examples use Trace, Traceoff, and TraceOn methods to create a trace file with SQL statements issues by the scripting query.
function BusComp_NewRecord ()
TheApplication().TraceOn("C:\\trace_output.txt", "SQL", "");
TheApplication().Trace("Start of tracing!");
var oBC = this.GetPicklistBusComp("Sales Stage");
with (oBC)
SetViewMode(AllView);
ClearToQuery();
SetSortSpec("Sales Stage Order(ASCENDING)");
ExecuteQuery(ForwardOnly);
if (FirstRecord())
Pick();
oBC = null;
TheApplication().Trace("End of tracing!");
TheApplication().TraceOff();
Sub BusComp_NewRecord
TheApplication.TraceOn "C:\trace_output.txt", "SQL", ""
TheApplication.Trace "Start of tracing!"
Dim oBC as BusComp
Set oBC = Me.GetPicklistBusComp("Sales Stage")
With oBC
.SetViewMode AllView
.ClearToQuery
.SetSortSpec "Sales Stage Order(ASCENDING)"
.ExecuteQuery ForwardOnly
If .FirstRecord Then
.Pick
End If
End With
Set oBC = Nothing
TheApplication.Trace "End of tracing!"
TheApplication.TraceOff
End Sub
Related Topics
For more information, see the following topics:
