WriteRecord Method for a Business Component
The WriteRecord method saves to the Siebel database any modifications made to the current record. This method does not return any information.
Format
oBusComp.WriteRecord
No arguments are available.
Usage
After creating new records and setting values for fields, you can call the Write Record method to save the new record to the Siebel database.
Used With
Browser Script, COM Data Control, COM Data Server, Siebel Java Data Bean, Mobile Web Client Automation Server, Server Script
Examples
The Siebel VB example in this topic implements the following logic: if the user sets the Sales Stage field to 02, then insert an activity:
(general)
(declarations)
Option Explicit
# Sub BusComp_SetFieldValue (FieldName As String)
' Run this code from the Opportunities Activities view.
' Opportunity is presumed to be the parent business component.
Select Case FieldName
Case "Sales Stage"
if Me.GetFieldValue(FieldName) LIKE "02*" Then
' reference the Action business component
Dim oBCact as BusComp
Set oBCact = me.BusObject.GetBusComp("Action")
With oBCact
.NewRecord NewAfter
.SetFieldValue "Type", "Event"
.SetFieldValue "Description", "THRU SVB, Stage _
changed to 02"
.SetFieldValue "Done", Format(Now(), _
"mm/dd/yyyy hh:mm:ss")
.SetFieldValue "Status", "Done"
.WriteRecord
End With
set oBCact = Nothing
end if
End Select
End Sub
For more examples, see GetMVGBusComp Method for a Business Component and NewRecord Method for a Business Component
