InsertOrder Method
Insert an order that is defined in the input. If the order already exists, then the method updates the existing order.
Syntax
Product Data Service.InvokeMethod(“InsertOrder", Input Arguments,Output Arguments);
Arguments
Argument Type Description
Input Arguments
In
Hierarchy :SiebelMessage(Integration object PDS Order)
Output Arguments
Out
Error Conditions
None.
This method calls the help method described in DeleteQuote Method.
