Modifying Lists of Values for Managing Public Sector Providers
There are two sets of UI elements that you must add values to:
Multivalue groups
Picklists
Modifying Values in Multivalue Groups
You can add values to multivalue groups, which are displayed in the dialog boxes that service providers use to choose certain options, so all service providers choose from the same list of values. For example, add values displayed in the dialog box that service providers use to choose which religions they can accommodate, so that every service provider chooses from the same list of religions.
It is recommended that you enter the values that you want displayed in the following dialog boxes in the Service Providers screen, Profile view:
Languages
Food
Expertise
Religions
To add values to dialog boxes
Navigate to the Service Providers screen, then Profile view.
For each field, click the Multiple Select button to display the dialog box.
In the dialog box, add a new record to add new records, and complete the necessary fields.
Modifying Values in Picklists
You can change values in picklists that you use to choose certain options, to suit your business model. For example, change the values available in the Type field of the Agreement record, so that it lists the types of agreements that you have with your service providers.
It is recommended that you modify the values in the picklists in the fields shown in the following image. You might also need to modify the values in other picklists, depending on your business model.
Screen and View |
Field |
Type Code in List Of Values Administration |
Agreements screen, Agreement List |
Type |
AGREEMENT_TYPE |
Status |
SRV_AGREE_STATUS |
Service Providers screen, Assets view |
Status |
IMPL_PHASE |
Service Providers screen, Service Providers Form |
Stage |
PARTNERSHIP_STAGE |
Status |
ACCOUNT_STATUS |
For more information about modifying picklists, see Siebel Applications Administration Guide.
To modify values in picklists
Navigate to the Data screen, then List of Values view.
In the List of Values list, in the Type field, query for the type code that you want listed in Modifying Lists of Values for Managing Public Sector Providers.
Add, modify, and delete records, so that there is one record with that type code for each option to be displayed in the picklist.
The Type field of the record must have the type code for the field, and the Display Value field of the record must have an option displayed in the picklist.
Click Clear Cache.
