Manual Signal Modifications for Communications, Media and Energy Applications
Note: If you automatically enable the Dynamic Pricing Procedure for all price lists as described in Step 2b of Switching from Basic to Dynamic Pricing Procedure, then you do not need to implement any of the modifications outlined in this topic.
This topic lists the manual signal modifications required to implement dynamic pricing for Siebel Communications, Media and Energy (CME) applications.
Note: If you are using tiered pricing, then the following signals should refer to Pricing Procedure - CME.
