About Predefined UI Properties
The following table shows the predefined UI properties that you can use. These UI properties provide commonly desired ways to modify the display of items. You do not need to insert a variable name for these properties into a customizable product Web template. You only need to assign them to the desired item in the Properties view. These properties apply to the Siebel Product Configurator installation.
Note: For external images, image files must be placed in Siebel Application Interface where Siebel Web Server Manager is installed. For example
Siebel_SWSM_Root\applicationcontainer_external\siebelwebroot\images
For more information on file paths, see Siebel Installation Guide.
Property Name Value Description
Excluded
Y
Cannot be defined on products within a relationship or attribute values.
When defined on a relationship, prevents all excluded items in the relationship from displaying.
If an item in a relationship is a product with components, does not prevent display of excluded products within that product with components.
When defined on the product root, prevents excluded items from displaying throughout the product.
When defined on the attribute definition, prevents excluded attribute values from displaying. This property is applicable for enumerated attribute definitions.
Hide
Y or N
When set to Y for any relationship, product or attribute, this value causes that item to be omitted from the UI selection pages during customization.
This UI property is very useful with class-products. For child products in the class, you can hide portions of the product structure inherited from the class-product. This allows you to define the class-product structure and then tailor its display for each of the child products that inherit the structure.
Can be defined on any part of a customizable product structure, shown on one side of the tree view that displays in the UI Properties administration view. Acts at the UI level, so if you add this UI property to hide the values that are selected in the existing quotes it does not remove these values from the structure, but only changes the display.
This property hides the item statically, so it remains hidden. You hide products dynamically using a different property, described in Creating Dynamic Siebel Product Configurator User Interface Controls .
Description
Enter a text string.
Define on relationships only.
Enter the text exactly as it will display to the user.
Images/<filename>
The image displays beside of relationship header. The image is displayed full size.
LearnMore
Enter the full URL to the desired location
Use with relationships only. Do not use with component products, resources, attributes, or links.
The words "Learn More" are displayed adjacent to the item and are a hyperlink to the URL you enter.
ProductHeader Image
Images/<filename>
Define on product root only.
Displays an image of the root product on every selection page. Image displays beneath item header, to one side of item labels. The default image area is 120x120 pixels square. Can only be defined on product root.
FullComputation
Y
When set to Y (Yes) and user makes an attribute selection, the Siebel Product Configurator engine updates the selection state of all the attribute values so that only selectable values are displayed. For example, if one of the values is excluded, it displays unavailable. Can cause performance reduction. This is the default.
When set to N (No), the Siebel Product Configurator engine does not update the selection state of the other attribute values and displays all the values as selectable. For example, if one of the values is excluded, it does not display unavailable. If users select an excluded value, they receive a conflict message.
Use this UI property when display of the selection state of attribute values is required.
Define on attributes with LOV domains only.
Resource
Y
Define on attributes only. When this property is set, the attribute value will be treated as engine picked, which works similar to a resource. This property is commonly used when an attribute is used as a counter that will not be changed directly by a user and that will be recalculated every time regardless what previous value or state is.
Default Group
The name of a valid group
This property specifies the default group loaded in the grandchild display.
Grandchild Enabled
Y
Define this property at the appropriate attribute group item level in order to show attributes in line with products in the grandchild display.
Grandchild Type
combo, text, radio
Define this property at the appropriate attribute group item level in order to show attribute in line with products in the grandchild display. This property specifies the type of attribute user-interface control to load.
MultiChildrenPort[N]
This property is used by the CP UI service. It lets the UI service know that before presenting a given group or the CP itself, the UI service needs to fetch more details about the user property value and relationship.
You can define this at the root level or at each group level for multiple relationships (Name: MultiChildrenPort, Value: Intrastate, Name: MultiChildrenPort1, Value: USA, Name: MultiChildrenPort2, Value: Canada, Name: MultiChildrenPort3, Value: Extended and so on, where Intrastate, USA, Canada, Extended are relationship names within the CP.
You would need to define this for each CP UI definitions. If you customize the OOTB template and add a template code to access child component information (attribute or relationship products) then you must define the root item as a multi children port. This is needed because the UICache used, may not contain the complete information needed for the UI (obsolete or not cached UI information such as accessing all attribute values of all products in the group item).
The disadvantage of using this is that there will be performance penalty if the total relationship domains affected by these user properties are large. If you use this user property several times, remember to give them names such as MultiChildrenPort, MultiChildrenPort1, MultiChildrenPort2 and so on. (You cannot use MultiChildrenPort0.)
MatchNewItemsInSolution
Y
When you have an asset with child products, and when you modify the asset and change its configuration, the engine removes all existing child items and then adds all new child items that fulfill the constraint rule. The Action Code field value changes from Delete, to Add.
When this user property is set to Y on the root customizable product, the engine maintains and updates the existing child items while fulfilling the constraint rule.
Note: If you require the Action Code field of the original instance of the component to have the value Update, then the Cfg State Code in the component in the asset hierarchy requires the value Engine Picked.
Grandchild Sequence
An integer greater than 0
This property is used to sort the grandchild attributes for display. Use it with the Grandchild Enabled property.
Configure the UI properties for all attributes with the names Grandchild Sequence and with the values as integers representing the sequence numbers. In the user interface, the attributes are shown in ascending order of the sequence set, using this UI property.
. For more information on file paths, see Siebel Installation Guide.
