About Working with Product Administration
This topic gives you background that you need for working with product administration.
Note: It is recommended that you do not use the Product Administration business object layer outside of the Siebel user interface. If you want to create product definitions through scripting, you can use the product import Web services to load product structures, product attributes, classes and relationships, but user interface controls and constraints cannot be loaded. For more information see Siebel CRM Web Services Reference. You can also use an external application to build the product structure XML file and automate the import of the XML file into a joint workspace.
