Adding the Validation Services Record
The Validation Services record contains the name of the validation business service to call. In this case, you use it to call the custom business service that you created.
To create validation services
Navigate to the Administration - Product screen, then the Products view.
Click the Product Validation view tab.
In the link bar of Product Validation view, click Validation Services.
Add one or more new records to the Validation Services list and complete the necessary fields, as described in the following table.
| Field | Comments |
Sequence |
Enter a number that controls the order in which the validation services are executed. You can create an unlimited number of validation services. |
Business Service |
Select the custom business service that you created to execute this rule. |
Rule Type |
Select a rule type. Options are:
The option you select depends on the custom validation service. |
