Assign the New Product Theme Template
To assign the new product theme template to the customizable product, you first add the template to the Pick UI Style dialog box. Then you select it as the product theme.
Click the magnifying icon.
This opens the Pick User Interface Style window.
Click the plus icon (+).
In the Template field, click the magnifying icon.
In the Query field, enter an asterisk (*) to list all Product Template templates.
Select the template you created in Creating a New Product Theme Template.
In the Pick User Interface Style window, enter the following information:
Name. Enter a descriptive name. For example: Modified Tab Theme.
Template. Enter the filename of the template you created.
Description (Optional). Enter a brief description of the template.
Click Save and OK.
