Basic Constraints
The following table shows how create basic constraints using Rule Assembly Language.
| Constraint Type | Advanced Rule Language |
A requires B noncumulatively |
A requires B cumulatively |
A excludes B |
A provides the amount B to C |
A consumes the amount B from C |
A's minimum quantity is B, enforced |
A's maximum quantity is B, enforced |
A recommends B |
