Business Component Links
Business component links map a Siebel business component data field to a link name. The link name can then be used when writing constraints for a customizable product.
To create a business component link, you must have a thorough understanding of Siebel business components and be able to use Oracle's Web Tools to identify business objects, business components, and field names.
When you define a business component link, the goal is to retrieve only one record. Several fields are provided in the link definition to help you do this. If more than one record is retrieved by the query, the link data is extracted from the first record in the group. If no records are retrieved by the query, the value entered in the default value field in the link definition is used.
You have the option to extract information from the current instance of a business component or from a new instance. For example, you select an account as part of creating a quote. You have defined a link for a complex product that extracts information from the business component that displays this record. When the user begins configuring the product, the link information will be extracted from the account record being used in the quote. The link uses the current instance of the business component.
