Configurator Load Workflow
Configurator Load Workflow, as shown in the following figure, loads the complex product model into memory and displays the Siebel Product Configurator user interface.
Workflow Description.
This workflow does the following:Load Instance. Loads the Product line item data structure through EAI and creates the CxObj memory structure for it. This step calls LoadEAI Method, which is described in the Copy Service reference in Siebel Order Management Infrastructure Guide.
Go to UI. Loads the Siebel Product Configurator user interface for the product.
