Creating Messages for Product Validation
If your custom business service uses Universal Messaging Service, you must use the Administration - Application screen, then the Message Types view to define the error messages that the product validation rule will display.
For more information about defining messages, see Siebel Order Management Infrastructure Guide.
To create the messages for product validation
Navigate to the Administration - Application screen, then the Message Types view.
In the All Message Types list, add a new record for each message and complete the necessary fields, as described in the following table.
| Field | Comments |
Name |
Enter a name for the message record. When you add rules in the Simple Validation Expression Rules list, this name will be used to link the rule to a message. |
Group |
If you are writing a custom validation service, give the group the name that you will call in the validation service. |
Full Text |
Enter the error message that is displayed by the application. Note: Only the Full Text field is used by
the product validation engine. The Short Text field is ignored. |
