Creating Time Slice Reports for Product Versions
You can produce time slice report for a customizable product versions. This report lists dependent objects that expire prior to the end date of the version.
If dependent objects expire, the product version may not work as intended. After viewing the time slice report, if necessary, you can change the end dates of existing versions of the dependent objects or create new versions of the dependent objects with later end dates.
The time slice report produced in Customizable Products, then Versions view only takes account of objects that have already been released. To produce the report for objects that have not been released, you must use Workspace Projects view and select the Use Project checkbox for the objects.
The time slice application preference determines the output format of time slice reports (XML or CSV). For information about setting application preferences, see Siebel Applications Administration Guide.
To create a time slice report for objects that have been released
  1. Navigate to the Administration - Product screen, then the Product Definitions view.
  2. In the Products list, select the desired customizable product.
  3. In the Versions list, select the version you want to run the report on.
  4. From the Versions list menu, select Create Time Slice Report.
To create a time slice report for objects that have not been released
  1. Navigate to the Administration - Product screen, then the Workspace Projects view.
  2. In the Workspace Projects list, add a new record and complete the necessary fields.
    The Use Project checkbox must be selected.
  3. In the Contents view, add all the objects that you want to run the report on.
  4. From the Workspace Projects list menu, select Create Time Slice Report.
