Creating a Configuration Constraint Summary Report
You can obtain a report that lists all the configuration constraints in a customizable product or product class. The report shows the following information:
  • Constraint name
  • Constraint Statement
  • Explanation
  • Start date
  • End date
  • Active
  • Updated date
  • Updated by
The Constraint Summary displays in the Siebel Report Viewer. You can print the report or create an email attachment.
This report must be enabled on the report server before performing the following procedure.
Tip: The on-screen display of the report typically lists more products on each page than the Products list. Use the report to scan quickly through the product table.
To create a constraint summary report
  1. Navigate to the Administration - Product screen.
  2. Select and lock the desired customizable product or product class.
    If you omit this step, the most recently released version of the customizable product is loaded in the Constraints view.
  3. Navigate to the Constraints view.
  4. In the application icon bar, click the Reports icon.
  5. In the Run Report applet, select Rule Summary.
