Data Operators in Rule Assembly Language
Use the following operators, as shown in the following table, when working with Siebel data types.
| Operator | Syntax | Properties |
Number |
Converts the operand to a number. Operand can be an expression. |
String |
Converts the operand to a string. Operand can be an expression. |
Date |
Converts string to a date. Operand can be an expression. |
Time |
Converts the operand to a time. Operand can be an expression. |
UtcDateTime |
Converts the operand to the UTC date and time. Operand can be an expression. |
DateTime |
Converts the operand to a date and time. Operand can be an expression. Not recommended for use. Use UtcDateTime instead. |
Currency |
Converts the operand to currency. Operand can be an expression. |
Phone |
Converts the operand to a phone number. Operand cannot be an expression. Can be used only with Equals (==) and Not Equal To (!=) operators to compare two phone numbers. |
