Defining Eligibility Groups
Eligibility groups are used to group eligibility rules that you create, for your own purposes.
For example, you can create one group for product eligibility rules and one group for promotion eligibility rules. Alternatively, you may decide to create one group for each product line. You can use any logical group that makes sense to your business.
Choose how to group eligibility rules based on your business needs.
To define an eligibility group
Navigate to the Administration - Product screen, then the Eligibility and Compatibility Matrices view.
In the Eligibility and Compatibility Matrices list, add a new record and complete the necessary fields, as described in the following table.
| Field | Comments |
Name |
Enter a name for a group. |
Matrix Type |
To make this an eligibility rule group, select Eligibility Rules. |
