Enabling the Customize Button
The user can select a configurable product and click the Customize button to customize the product. However, the Customize button is only enabled when the user's responsibilities include one of the appropriate views that allows users to customize products. The following views of the Quotes screen are examples of views that enable the customize button:
  • Complex Product Runtime Instance View
  • Complex Product Runtime Instance View - Order
  • Complex Product Runtime Instance View - Shopping Cart
Within these views, the Customize button is enabled only when the type of the product is Customizable.
To find a complete list of the views that enable the Customize button
  1. Open Oracle's Web Tools.
  2. In the Views tab, search for views that match the following:
    Complex Product Runtime Instance View*
