Excluding Values in the Administration - Product Screen
You can specify in the Administration - Product screen that certain values are excluded based on the expression variables defined by Set Procedural Conditional Variable rules. You can do this using the property, CondExcl=exprVarName. The attribute values or products in the domain with this property are shown as excluded when exprVarName evaluates to true.
To exclude values based on Set Procedural Condition Variable rules
Navigate to Administration - Product screen, then the Products Definitions view.
In the Versions list, drill down on the Workspace version of the product.
Click the Properties view tab.
In the Properties list, add a new record and complete the necessary fields, as described in the following table.
| Field | Comments |
Name |
Enter CondExcl. |
Value |
Enter an expression variable. The attribute values or products in the domain with this property are shown as excluded when this variable evaluates to true. |
