GetConditionVal Method
This method allows users to call and retrieve the values of the named expression variables.
Input Arguments
  • CondName. The name of the condition variable.
  • IntId. The integration id of the product.
Output Arguments
If the condition variable is found and evaluates to true, the property Result is set to Y in the output arguments. If not, the Result is set to N.
For example, define a Product as follows:
Class1
-> Att1
Product: Child1 (associated with Class1)
Attribute: Att1 (which has the default value of one)
Constraints List:
Constraint: The attribute SekAtt1 = one sets the value of the procedural condition variable to true
Product: Root (associated with Class1)
Re1: Child1
You can use the following script:
function Cfg_AttributeChanged (ChangedAttribute)
var Service = TheApplication().GetService("Configurator Service");
var Variable ="RuleOne";
var VariableVal = "";
var IntegrationID= AddItem("$.[Root]#1", "R1", "Child1", "1")
var InputArgs = TheApplication().NewPropertySet();
var OutputArgs = TheApplication().NewPropertySet();
InputArgs.SetProperty("CondName", Variable);
InputArgs.SetProperty("IntId", IntegrationID);
Service.InvokeMethod("GetConditionVal", InputArgs, OutputArgs);
Variable = OutputArgs.GetProperty("Result");
if (Variable == "Y")
TheApplication().RaiseErrorText("True" );
else
TheApplication().RaiseErrorText("False" );
