Items
An item in an exclude constraint can be any of the following:
  • A relationship or class within a relationship
  • A product within a relationship or class
Here is how the exclude constraint works with items:
  • Product A excludes Product B
    If Product A is present in the solution, then Product B cannot be present. If Product B is present in the solution, then Product A cannot be present.
  • Relationship A excludes Product B
    If any product in Relationship A is present in the solution, then Product B is excluded. If Product B is present, then no product from Relationship A can be present.
  • Relationship A excludes Relationship B
    If any Product in Relationship A is present in the solution, then no product in Relationship B can be present. If any product in Relationship B is present in the solution, then no product from Relationship A can be present.
