Modify the Constraints View Applet
This task adds the Rule Spec field to the Cfg SWE Rule Manager Applet.
To modify the Constraints View applet
With the SWE Rule Manager Applet highlighted, select Tools, Lock Project.
Right click the highlighted applet record and select Edit Web Layout.
In the window displaying the layout, right-click and select Preview from the pop-up menu.
Click the Template icon and select the Applet List (Base/EditList) template. It is the default.
In the Mode drop-down menu, select 3: Edit List.
In the Controls/Columns window, click Rule Spec, and move it to the [field] beside the End date in the applet display.
Click Save.
Click OK to save your changes.
Deliver the workspace.
