More on the Logical Equivalence Operator
As a top level constraint, the logical-equivalence operator (eqv()) creates a mutually-requires relationship between its operands. The operands can be either items or sub-expressions. For example eqv([A], [B]) means than if item A is in the solution, then at least one item B must be in the solution. Also, if item B is in the solution, then at least one item A must be in the solution. Note that the relationship between [A] and [B] is noncumulative. (Use the inc() operator to create cumulative-requires relationships.)
For example, the following constraint states that if the quantity of [A]>2, then [B] is required.
eqv(>([A],2),[B])
This expression constrains the solution as follows:
If there are more than two A's in the solution, there must be at least one B.
If there cannot be any B's in the solution, there cannot be any more than two A's.
If B is in the solution, there must be more than two A's.
If A is limited to two or less, B is excluded.
