Multiple Operands
You can add multiple operands to a require constraint by clicking the Compound Field button when you create the constraint.
For example, you could create the constraint:
Item A requires Item B > 2, Item C < 5
This constraint means the following:
  • If Item A is present in the solution, the quantity of Item B must be greater than 2
  • If item A is present in the solution, the quantity of Item C must be less than 5
  • If Item B cannot be greater than 2 in the solution, Item A is excluded
  • If item C cannot be less than 5 in the solution, Item A is excluded
This is the same as writing two constraints:
Item A requires Item C < 5
