Overview of Using the Constraints view
When you create constraints, you use the constraints view in the following way:
  1. In the constraint template listing, select the desired constraint template.
  2. Select the first variable in the constraint.
  3. Click the desired item grouping.
  4. Pick the product, operator, or constraint template you want to insert.
  5. Move to the next variable and insert the desired item.
  6. When you are finished, save the constraint.
