Quote Integration and Configuration Assistant in Version 6.x and 7.x
Creating a model product and associating a model with it is not required in version 7.0 and 7.5. Instead, you create a customizable product work space, which is similar to creating a record in the Model Manager in version 6.x. This work space associates the parts of the customizable product, including its components, links, resources, and UI definition with the product record. When you release a new version of the customizable product, it becomes available immediately for configuration in quotes and in eSales Web pages.
In version 6.x, the Configuration Assistant view was used to display models, select items, and transfer items to a quote. If you wanted to modify how the Configuration Assistant looked, you had to use Oracle's Web Tools to build a new view. In version 7.0 and 7.5, a Product UI Designer is provided within Siebel Product Configurator to create the browser pages, called selection pages, that will display during a configuration session. You can select from several base themes and product themes that define basic page layout. You can also select the controls, such as radio buttons or check boxes, to use for displaying items.
The base themes, product themes, and controls are stored in template files that you can customize or use to create your own templates. In addition, you can use the User Interface Property Designer to customize how individual items display. If you do not want to create a user interface for a customizable product, the application provides intelligent defaults for creating selection pages automatically. The following table maps version 6.x features to version 7.0 and 7.5 for quote integration and Configuration Assistant.
| Version 6.x | Version 7.0 and 7.5 | Comment |
Verify a solution |
Verify a customizable product configuration. |
None. |
Verify a quote |
Verify a quote. |
None. |
Update a quote |
Update a quote. |
None. |
Solution name |
Customizable product name. |
None. |
Solution quantity |
Customizable product quantity. |
None. |
Line item quantity |
Component quantity in a customizable product. |
None. |
Reconfigure a solution with a new version of a model |
Reconfigure a stored session with a newer version of a customizable product |
None. |
Create and manage Favorites |
None. |
Add an item in a configuration session |
Same. Define item display in Product UI Designer |
You can also accept application defaults for item display |
Remove an item |
Add a category |
Add a relationship in Structure view |
None. |
Unsatisfied category icon |
A flag displays when a relationship is below its minimum cardinality or is required. |
None. |
Finish It! |
Finish It! |
None. |
Item state explanation |
The user interface contains an Explanation button. |
Clicking the Explanation button displays an explanation. |
Item properties displayed in applet |
Properties have been replaced by configurable attributes. Attributes display in configuration session or in Quotes, then Dynamic Attributes. |
None. |
Messages and Recommendations |
None. |
Unsatisfied requirement message |
None. |
Quantity out of range message |
None. |
Conflict-exists pop-up message |
Explanation and ability to proceed or cancel user action is supported |
Edit quantity of an item |
Requires UI control that allows editing of quantity. |
