ResetObjInSKC Method
This method posts a request to invalidate a specific cached object definition. The application does this logically by querying the ISS VOD Cache Sync business component to find the record based on the Type and VodId input parameters. If a record is found then the field values for that specific record are reset.
Input Arguments
  • Type. The type of the VOD object. Valid values are: ISS_ATTR_DEF, ISS_CLASS_DEF or ISS_PROD_DEF.
  • VodId. The value of the VOD object Id. This value must match the value found in either the S_VOD.OBJECT_NUM or the S_PROD_INT.CFG_MODEL_ID field.
Note: Both input arguments are required.
Output Arguments
Not applicable.
