SyncInstance Method
This method saves the complex object instance where it originated.
Input Arguments
ObjId. The unique identifier of the complex object header.
RootId. The unique identifier of the complex object root (for example, Quote Line Item row Id).
IntObjName. The name of the integration object specified in Oracle's Web Tools.
(Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
Output Arguments
None
