Viewing Related Objects for Product Classes
The Product Class Cross References view allows you to view the objects that are related to a product class, including:
  • Subclasses. Classes that are a child to the product class
  • Products. Products that have the product class as a parent product class
  • Relationships. Objects that use the product class to form relationships
  • Attribute Adjustments. Attribute Adjustments that use the product class
The user can drill down on any of these line item to display the administration view for that object.
Note: The Cross References list applies to one version of a product class, because different versions may include different direct subclasses. Versions include Workspace versions.
To view related objects for a product class
  1. Navigate to the Administration - Product screen, then the Product Classes view.
  2. In the Product Classes list, select the class whose related objects you want to view.
  3. In the Versions list, click the name of version whose related objects you want to view.
  4. Click the Cross Reference view tab.
  5. In the Cross Reference link bar, click Subclasses, Products, Relationship, or Attribute Adjustments to view lists of related objects.
