About the Standard Routing Model
A user whom you assign to the Mobile Client - Standard routing model receives the full data set. The following items typically determine the data that this user can view:
Position
Ownership
Organizational structure
Visibility of items in the following views:
My View
My Team View
For example, My Team’s Opportunities.
Siebel Remote also routes data that is visible at the enterprise level that typically includes metadata or the setup data that the Siebel application requires. For more information, see How Positions, Organizations, and Responsibilities Affect Access.
Dock Objects That the Mobile Client-Standard Routing Model Does Not Include
The following table describes the dock objects that the Mobile Client-Standard routing model does not include.
| Dock Object | Description |
Activities  |
This routing model does not route the following activities:
Assets  |
Assets that visible invoiceable charges reference.  |
Audit Log  |
Audit trail data that is associated with all objects.  |
Barcode  |
Barcode configuration information.  |
Call Script Question  |
Data that is associated with SmartScript functionality.  |
CHAMP  |
Data that the CHAMP methodology requires.  |
Comm (Marketing Campaign)  |
Data that is associated with Marketing Campaign functionality.  |
Content Set  |
Data that is associated with Content Base functionality.  |
Content Type  |
Data that is associated with configuration of Content Base functionality.  |
CTI Cfg  |
CTI configuration data that CTI functionality requires.  |
DD Filter  |
Data that is associated with filters that Marketing Campaign functionality requires.  |
DD Hierarchical Attribute  |
Data that is associated with Hierarchy (family function) that Marketing Campaign functionality requires.  |
DD List Format  |
Data that is associated with Lists that Marketing Campaign functionality requires.  |
DD Measure  |
Data that is associated with Measures that Marketing Campaign functionality requires.  |
DD Measure-based Attribute  |
Data that is associated with Measure Based Attributes that Marketing Campaign functionality requires.  |
DD Sort Family  |
Data that is associated with Parent for Sort Family that Marketing Campaign functionality requires.  |
DD Source Code Format  |
Data that is associated with Source Code Format that Marketing Campaign functionality requires.  |
DocAgreement  |
DocAgreement that a visible invoiceable charge references.  |
Docking Object  |
Data that is associated with the data definition of the Siebel Remote Docking Object.  |
DockRoute  |
Data that is associated with the Siebel Remote Routing Model.  |
DocQuote  |
DocQuote that visible Revenue references.  |
EAI Lookup Map  |
Data that EAI components use to map external application values to Siebel values and to map Siebel values to external application values.  |
Employee Skill  |
Employee skills data.  |
Expense  |
Expense reports that a visible invoiceable charge references.  |
Group News  |
Data that is associated with Content Path.  |
Integration Object Map  |
Data that is associated with EAI Integration Object mapping.  |
Invoicable Charge  |
Visible Charges and credits data that can be invoiced to customers or that the employee creates.  |
List of Value  |
List of value data that the remote client does not require.  |
MS Project Integration  |
Seed data that maps Microsoft Project fields to Siebel Project fields.  |
Note  |
A note that is associated with quote, literature, or other objects that do not contain a note table.  |
Order  |
Visible order data that can be invoiced to customers.  |
Org Source  |
Accounts to be targeted for a promotion.  |
Outlook Integration  |
Seed data that Siebel CRM uses to define business components, business objects, views, and applets that display items in Microsoft Outlook.  |
Party  |
Party data that a visible invoiceable charge references. Contact records that the CTI configuration teleset references. Party data that a visible quote references. User roles that are associated with the user.  |
Postal Code  |
ZIP code data.  |
Product  |
Product data that a visible invoiceable charge references.  |
Project  |
Project data that a visible invoiceable charge references.  |
Project Item  |
Project item data that a visible invoiceable charge references.  |
PrspCon  |
Prospect.  |
Repair Part  |
Repair part data a visible invoiceable charge references.  |
Server Domain  |
Server domain information that a PIM (Siebel Server Sync) synchronization that is server based uses.  |
Server Domain List of Value  |
List of values for PIM language independent code that a PIM synchronization that is server based uses.  |
Server Domain Profile  |
Server domain configuration that a PIM synchronization that is server based uses.  |
Server Domain Translation Map  |
Server domain translation map that a PIM synchronization that is server based uses.  |
Service Request  |
Service request that a visible and invoiceable charge references.  |
SMQ Administration  |
Message business object information for MQ.  |
SMQ History  |
History information for MQ.  |
Task-Based Process  |
Task definition data that an administrator indicates through the administrative screens for regional node only.  |
Terr Accnt (Territory Account)  |
Territory account data that is the Territory Alignment process uses on the Siebel Server.  |
Terr Algn (Territory Alignment)  |
Territory alignment data that the Territory Alignment process uses on the Siebel Server.  |
Terr Asset (Territory Asset)  |
Territory asset data that the Territory Alignment process uses on the Siebel Server.  |
Terr Con (Territory Contact)  |
Territory contact data that the Territory Alignment process uses on the Siebel Server.  |
Terr Hier (Territory Hierarchy)  |
Territory hierarchy data that the Territory Alignment process uses on the Siebel Server.  |
Terr Region (Territory Region)  |
Territory region (brick) data that the Territory Alignment process uses on the Siebel Server.  |
Terr ZIP (Territory ZIP)  |
Territory ZIP code data that the Territory Alignment process uses on the Siebel Server.  |
Time Sheet Item  |
Time sheet item that a visible invoiceable charge references.  |
Universal Inbox Item  |
Universal inbox item data that the system administrator does not mark for replicating to the remote client.  |
Universal Inbox Item Typ  |
Universal inbox item type data that the system administrator does not mark for replicating to the remote client.  |
Workflow  |
Workflow process or step that the system administrator does not mark for replicating to the remote client.  |
Workflow Definition  |
Workflow deployment definition that the system administrator does not mark for replicating to the remote client.  |
