Creating Accounts and Passwords
This task is a step in Process of Configuring Encryption and Authentication for the Remote Client.
You must create an account for each client to authenticate a remote client when it synchronizes. The authentication method you choose determines the account you must create.
To create accounts and passwords
  • Create an account and password according to the type of authentication you use. Use values from the following table.
Authentication Work You Must Do
AppServer authentication
Create a user account on the Siebel Server for each remote client:
For more information, see How the Change Password Functionality Affects Authentication.
Database authentication
Create a database account and password for each remote client.
Siebel authentication
Do the following:
  • Access the Mobile Clients view of the Administration - Siebel Remote screen, and then set the password for each remote client.
  • Communicate the password to the user so this user can synchronize with the Siebel Server.
SecurityAdapter authentication
Create the accounts and passwords that your third party authentication system requires. For example, it might be necessary for you to create records in an LDAP folder.
No authentication
Do not create accounts or passwords for authentication.
