Options for Configuring How Frequently Siebel Remote Uses TrickleSync
Siebel Remote describes options you can specify to configure how frequently Siebel Remote uses TrickleSync.
Option Description Retry
System boot up
Do the next synchronization after the computer starts and is operational.
If a network connection is not available, then try again the next time the computer reboots.
Mobile Client Startup
Synchronize after the remote client starts.
If a network connection is not available, try again the next time the remote client starts.
Minutes
Synchronize at the interval in minutes that the Minutes picklist specifies. You can configure a TrickleSync synchronization to occur as frequently as every 10 minutes.
Not applicable.
Hourly
Synchronize every hour at the minute after the hour that the Hourly At field specifies. For example, if the Hourly At field is 25, then Siebel Remote synchronizes at a 1 to 25 ratio, a 2 to 25 ratio, and so on.
If the computer is not operational at the specified time, then Siebel Remote synchronizes at the earliest time when the computer is operational.
Daily
Synchronize every day at the time that the Daily At field specifies. For example, to specify synchronization to occur every day at 10:00 in the evening, you can enter 10:00 PM. It is not necessary to enter periods in PM.
Weekly
Synchronize every week on the day that you choose in the Weekly On picklist, and at the time that you enter in the Weekly At field.
