Setting Preferences for Visibility, Logging, Timestamps, and Conflict Resolution
This task is a step in Process of Completing the Remote System Preferences Form.
To set preferences for visibility, logging, timestamps, and conflict resolution
Navigate to the Administration - Siebel Remote screen, and then the Remote System Preferences view.
 In the Remote System Preferences form, place a check mark next to the Optimized Visibility Check check box.
For more information, see Configuring System Preferences for Transaction Logging.
Make sure the Enable Transaction Logging field is set correctly to enable transaction logging.
To use Siebel Remote, you must enable transaction logging. For more information, see Configuring System Preferences for Transaction Logging.
In the Docking Timestamp Source field, specify the source for the timestamp.
For more information, see Configuring System Preferences for Timestamps.
In the System Conflict Resolution field, specify how Siebel Remote resolves conflicting database updates. Use a value from the table in Dock Objects.
Caution: For important caution information about setting system conflict resolution, see Requirements for Extracting the Server Database.For more information, see Update Conflict.
In the Intersection Table Conflict Resolution field and in the Intersection Table Merge Rule field, specify how to handle a record that is involved in an insert conflict.
For more information, see Configuring System Preferences for Resolving Conflicts.
How Optimized Visibility Can Improve Performance
If the Optimized Visibility Check check box contains a check mark, then the Transaction Router server component uses a predefined algorithm to examine visibility. This algorithm uses information that an individual transaction carries to reduce the number of visibility rules that Siebel Remote examines. The algorithm reduces the number of database queries that the Transaction Router requires which improves performance. It is recommended that you use this algorithm in most situations.
