Using EIM to Create Multiple Siebel Remote Clients
You can use EIM (Enterprise Integration Manager) to do a batch load if Siebel Remote must load a significant amount of data, such as when it creates a large number of remote clients. If you use EIM to import records to the server database, then Siebel Remote logs transactions in the file system to improve performance. If a remote client possesses read and write access to the records that EIM imports during an EIM session, then it is strongly recommended that you use row by row logging. For more information, see Siebel Enterprise Integration Manager Administration Guide.
If your deployment includes Replication Manager, then Siebel CRM supports this EIM functionality only on the Siebel Server of the headquarters node. For more information about headquarters nodes, see Overview of Siebel Replication Manager. For more information on how to load data in interface tables, and then populate base tables, see Siebel Enterprise Integration Manager Administration Guide.
