Using Event Logging with Server Components
Event logs provide helpful information for diagnosing problems. For example, to log information for the Database Extract server component, you can enter the following command in the Server Manager command line interface:
change evtloglvl GenericLog=5, Trace=5, SQL=5, EVENT_GENERIC_PROFILE=5 for comp dbxtract
start task for comp dbxtract server server_name with Client=client_name, SQLFlags=2, TraceFlags=7
