Using Replication Agent to Control Synchronization
To control synchronization, you can modify the parameters of the Replication Agent server component.
To use Replication Agent to control synchronization
Modify parameters of the Replication Agent server component.
You can modify the following generic format to start Replication Agent from the Server Manager:
start task for comp repagent server server_name with parameter_1= value_1, parameter_2= value_2,...
For more information, see Parameters of the Replication Agent Server Component.
