Using the Move Siebel Remote Client Parameter
If the remote client is currently registered on a Siebel Server that is not the current server, and if you set the Move Siebel Remote Client parameter to TRUE, then the following occurs:
- The Database Extract server component sets the Siebel Server name of the remote client to the local Siebel Server.
- The following server components on the old server stop servicing this remote client in the next iteration: - Transaction Router
- Transaction Merger
- Database Extract
You can also use the Move Siebel Remote Client parameter to move a regional node in the same way you that you use this parameter to move a remote client.
The default value is FALSE.
If you attempt to extract a remote client that Siebel Remote already extracted for a different server, then the Database Extract server component returns an error.
