Using the Txnutl Utility to Examine Corrupt Transactions
The Txnutl utility gathers information about the transactions that DX files contain or that exist in the transaction log table (S_DOCK_TXN_LOG). For example, if the transaction log table contains a corrupt transaction, then you can use txnutl to identify the corrupt transaction. You can also use Txnutl to open and examine the contents of a DX file to help resolve an error that occurs when Siebel Remote processes the DX file.
The Txnutl utility can provide information in the following ways:
To receive output on your computer monitor, you can not specify an output file.
To place output in a legible text file, you can append the output_file_name parameter at the end of the command.
To place output in compressed files, you can specify parameters for the command that runs the utility.
For more information, see Modifying the S_DOCK_TXN_LOG Table.
To use the Txnutl utility to examine corrupt transactions
Configure parameters for the session.
For more information, see Configuring Session Parameters for a Utility.
Enter the following command in a single line:
txnutl /u username /p password /r input_file_name /m y or n /s start_txn_id /v [y/n] /e end_txn_id /w output_file_name /x y or n
Use parameters described in the following table.
Parameter Required Description u username
Required
The login name for the administrator.
p password
Required
The password for the administrator.
r input_file_name
Required
The path and file name of the DX file or XML file that you must examine. If the file is in XML code, then you must also set the m parameter to y.
m y or n
Optional
Specifies if the input file is in XML code. If you use the Txnutl utility to examine transactions that reside in an XML file, then you set the m parameter to y to indicate that the input file is in XML code.
For example, if you set the x parameter to y on a previous run of the Txnutl utility, and if you must use this output as input to a subsequent run of txnutl, then you set the m parameter to y.
The default value is N for no, which indicates that the input file is not in XML code.
s start_txn_id
Optional
If you use the Txnutl utility to examine a range of transactions that exist in the S_DOCK_TXN_LOG table, then you use the s parameter to specify the transaction ID number that immediately precedes the range that you must examine.
e end_txn_id
Optional
If you use the Txnutl utility to examine a range of transactions that exist in the S_DOCK_TXN_LOG table, then you use the e parameter to specify the last transaction ID of the range that you must examine.
w output_file_name
Optional
Specifies an output file name:
If you include the w parameter, then the Txnutl utility does not write to the S_DOCK_TXN_LOG table.
If you do not include the w parameter, then the Txnutl utility writes to the S_DOCK_TXN_LOG table.
To prevent the Txnutl utility from creating duplicate records in the S_DOCK_TXN_LOG table, previous versions of Siebel Remote required that you use the w parameter. This parameter is optional.
x y or n
Optional
If you set the x parameter to y, then the Txnutl utility writes the output file in XML code instead of writing in the DX file format. The default value is N.
The following is an example of a typical command that runs the Txnutl utility:
txnutl /u sadmin /p sadmin /r my_input.dx /w abc.dx
where:
Txnutl is the name of the utility.
sadmin
is the user name.sadmin is the password.
my_input.dx is the name of the input file.
abc.dx is the name of the DX file.
You can arrange these parameters in any order.
Examine the output file.
