HP-UX Operating System
On the HP-UX operating system, the name of the library path environment variable is SHLIB_PATH. Depending on whether you source the siebenv.csh or the siebenv.sh script, set the SHLIB_PATH variable as follows:
siebenv.csh
if ($?SHLIB_PATH) then setenv SHLIB_PATH ${SIEBEL_ROOT}/lib:${SIEBEL_ROOT}/lib/odbc/merant:/$ORACLE_ HOME/lib:${MWHOME}/lib:${SQLANY}/lib:/usr/lib:${SHLIB_PATH} else setenv SHLIB_PATH ${SIEBEL_ROOT}/lib:${SIEBEL_ROOT}/lib/odbc/merant:/$ORACLE_ HOME/lib:${MWHOME}/lib:${SQLANY}/lib:/usr/lib endif
siebenv.sh
if [ a${SHLIB_PATH} = ${SHLIB_PATH}a ] then SHLIB_PATH=${SIEBEL_ROOT}/lib:${SIEBEL_ROOT}/lib/odbc/merant:/$ORACLE_ HOME/lib:${MWHOME}/lib:${SQLANY}/lib:/usr/lib else SHLIB_PATH=${SIEBEL_ROOT}/lib:${SIEBEL_ROOT}/lib/odbc/merant:/$ORACLE_ HOME/lib:${MWHOME}/lib:${SQLANY}/lib:/usr/lib:${SHLIB_PATH} fi export SHLIB_PATH
