Arguments for Invoke Command Method
The following table lists the arguments for the Invoke Command method.
| Argument Display Name And Data Type | Argument Name | Type | Req’d | Comment |
Command Tracking ID (type: String) |
CommandTrackingID |
Input |
Yes |
Command ID |
Data Set (type: Hierarchy) |
DataSet |
Input |
Yes |
Data parameters for driver |
Device Command (type: String) |
DeviceCommand |
Input |
Yes |
Command to be invoked in driver |
Driver Profile ID (type: String) |
DriverProfileID |
Input |
Yes |
Row ID of driver profile which is invoked |
Profile Name (type: String) |
ProfileName |
Input |
Yes |
Name of driver profile which is invoked |
String Parameter (type: String) |
StringParam |
Input |
Yes |
Single string data |
