Arguments for Notify Event Handling Finished Method
The following table lists the arguments for the Notify Event Handling Finished method.
| Argument Display Name And Data Type | Argument Name | Type | Req’d | Comment |
Result (type: Number) |
Result |
Input |
Yes |
Result code |
Work Item ID (type: String) |
WorkItemID |
Input |
Yes |
Work item ID |
