Arguments for Set Work Item Attributes Method
The following information lists the arguments for the Set Work Item Attributes method.
Note: For this method, you can set values for one or more attributes for the work item, using key-value pairs rather than arguments with fixed names. (By contrast, the methods Get Inbound Work Item Attributes and Get Work Item Attributes use the Attribute Name and Attribute Value arguments to store the name of a single attribute to retrieve, and its value, respectively.)
Argument Display Name And Data Type Argument Name Type Req’d Comment
Work Item ID
(type: String)
WorkItemID
Input
Yes
Work item ID
