Guidelines for Optimizing Oracle Parallel Queries for Siebel Web Tools
Several queries performed by Siebel Web Tools or Siebel Tools can benefit from the parallel
query feature for Oracle Database. Parallel hints have been added to the SELECT
statements for such queries for Siebel Web Tools and Siebel Tools. The Siebel component parameter
Oracle Degree of Parallelism (alias OraDegreeOfParallelism) allows setting the degree of
parallelism for Siebel Web Tools or Siebel Tools, where parallel hints are present in the
SELECT statements.
By default, the setting of OraDegreeOfParallelism is auto, which requires
parallel settings in the Oracle Database, and might affect development work in other areas.
To optimize parallel queries, it is recommended to set OraDegreeOfParallelism for the Siebel
Web Tools component to a value of 4. To do so, enter a command like the
following in Server Manager:
change param OraDegreeOfParallelism=4 for comp SWToolsObjMgr_enu
To set this parameter for Siebel Tools, add OraDegreeOfParallelism under the [Siebel] section
in tools.cfg, and set it to 4.
False, to
True. If OraOptimizerIgnoreHints is set to True, then
OraDegreeOfParallelism has no effect.For more information using Server Manager and about setting component parameters, see Siebel System Administration Guide.
This topic is part of Configuring an Oracle Database for Siebel CRM.
