Using Hook Point 1 and Hook Point 3
This topic describes how to use only hook point 2. To make sure the output is correct, hook point 1 and hook point 3 are disabled. If you require hook point 1 or hook point 3, then make sure you do the following work:
Modify the XSLT transformation files for hook point 1 and hook point 3.
Set the corresponding DVM parameters to true.
