Roadmap for Using Siebel Territory Management
To use Siebel Territory Management, perform the following processes and tasks:
Set up divisions and positions.
Set up territory hierarchy.
Set up territory nodes.
Set up the alignment (rules and conditions)
Run the alignment.
Review the alignment. Are the test results OK?
If No, return to Step 4.
If Yes, continue to Step 7.
Activate/schedule the alignment (roll out)
Review the territories and their rules.
(Weekly) Maintain the alignment.
Note: Setting up the alignment (rules and conditions) should be revisited on a quarterly or semi-annual basis.
The following illustrates the workflow of Territory Management in Consumer Goods.
| Button | Code | Available | Comments |
Apply |
HORZ |
SIA |
Will also work in HORZ if exposed in UI |
Apply All |
HORZ |
SIA |
Assign Activities |
SIA |
SIA |
Will work only in SIA |
Remove Activities |
SIA |
SIA |
Apply Multiple Categories |
SIA |
SIA |
