Additional Information Required for Apply Additive Schema Changes Mode
You can optionally run the Database Configuration Utilities in
Apply Additive Schema Changes mode. Additive Schema Changes generates
an SQL script, schema.additive.sql. The script contains
production upgrep schema changes that can be performed while the database
is online. This reduces the amount of time required for the upgrep
when the database is offline.
The additional information shown in the following table is required when you run the Database Configuration Utilities in Apply Additive Schema Changes mode.
Field Name |
Required Information |
Schema File |
The absolute path to the |
Output Directory |
The absolute path to the directory where |
